Time Before: 0.00169 seconds
Time After: 0.00219 seconds
Time Before: 0.00226 seconds
Time After: 0.00270 seconds
Time Before: 0.00293 seconds
Time After: 0.00308 seconds
Time Before: 0.00382 seconds
Time After: 0.00647 seconds
Time Taken: 0.00265 seconds
Time Before: 0.00312 seconds
Time After: 0.01203 seconds
Time Taken: 0.00891 seconds
Time Before: 0.01461 seconds
Time After: 0.01506 seconds
Time Before: 0.01758 seconds
Time After: 0.01884 seconds
Memory Before: 2,148.938 KB
Memory After: 2,148.797 KB
Time Before: 0.01385 seconds
Time After: 0.01908 seconds
Time Taken: 0.00523 seconds
Memory After: 2,261.820 KB
Time Before: 0.02419 seconds
Time After: 0.02432 seconds
Memory Before: 2,815.367 KB
Memory After: 2,815.883 KB
Time Before: 0.02654 seconds
Time After: 0.02776 seconds
Memory Before: 2,903.563 KB
Memory After: 2,904.156 KB
End call of global.php: 0.029675960540771
Time Before: 0.03116 seconds
Time After: 0.03142 seconds
Memory Before: 3,540.328 KB
Memory After: 3,540.758 KB
Time Before: 0.03368 seconds
Time After: 0.03516 seconds
Memory Before: 3,821.859 KB
Memory After: 3,823.547 KB
SET lastactivity = 1789104791, location = '/forums/private.php?do=newpm&explain=1&u=122709'
Time Before: 0.04815 seconds
Time After: 0.04837 seconds
Memory Before: 4,287.563 KB
Memory After: 4,287.781 KB
Page generated in 0.047053098678589 seconds with 9 queries, spending 0.0082433223724365 doing MySQL queries and 0.038809776306152 doing PHP things.
