Time Before: 0.00211 seconds
Time After: 0.00277 seconds
Time Taken: 0.00066 seconds
Time Before: 0.00284 seconds
Time After: 0.00327 seconds
Time Before: 0.00346 seconds
Time After: 0.00365 seconds
Time Before: 0.00463 seconds
Time After: 0.00770 seconds
Time Taken: 0.00307 seconds
Time Before: 0.00373 seconds
Time After: 0.01275 seconds
Time Taken: 0.00902 seconds
Time Before: 0.01571 seconds
Time After: 0.01615 seconds
Time Before: 0.01786 seconds
Time After: 0.01906 seconds
Time Before: 0.01468 seconds
Time After: 0.01933 seconds
Time Taken: 0.00465 seconds
Time Before: 0.02663 seconds
Time After: 0.02678 seconds
Time Before: 0.02935 seconds
Time After: 0.03061 seconds
End call of global.php: 0.032585859298706
Time Before: 0.03397 seconds
Time After: 0.03417 seconds
Time Before: 0.03639 seconds
Time After: 0.03783 seconds
SET lastactivity = 1776694037, location = '/forums/private.php?do=newpm&explain=1&u=122711', badlocation = 1
Time Before: 0.05266 seconds
Time After: 0.05301 seconds
Memory Before: 4,288.547 KB
Memory After: 4,288.758 KB
Page generated in 0.051709890365601 seconds with 9 queries, spending 0.0087275505065918 doing MySQL queries and 0.042982339859009 doing PHP things.
