Time Before: 0.03458 seconds
Time After: 0.04487 seconds
Time Taken: 0.01029 seconds
Time Before: 0.04497 seconds
Time After: 0.04537 seconds
Time Before: 0.04556 seconds
Time After: 0.04567 seconds
Time Before: 0.04648 seconds
Time After: 0.04876 seconds
Time Taken: 0.00229 seconds
Time Before: 0.04576 seconds
Time After: 0.05318 seconds
Time Taken: 0.00742 seconds
Time Before: 0.07100 seconds
Time After: 0.07136 seconds
Time Before: 0.07418 seconds
Time After: 0.07535 seconds
Time Taken: 0.00117 seconds
Time Before: 0.07016 seconds
Time After: 0.07554 seconds
Time Taken: 0.00538 seconds
Time Before: 0.12207 seconds
Time After: 0.12225 seconds
Time Before: 0.16207 seconds
Time After: 0.16337 seconds
Time Before: 0.18220 seconds
Time After: 0.18238 seconds
Time Before: 0.18517 seconds
Time After: 0.18659 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=122719', badlocation = 1 WHERE sessionhash = '05bc7c79f91873f78083814ccb7adf41'
Time Before: 0.20755 seconds
Time After: 0.20784 seconds
Memory Before: 4,288.203 KB
Memory After: 4,288.430 KB
