Time Before: 0.01894 seconds
Time After: 0.02506 seconds
Time Taken: 0.00612 seconds
Time Before: 0.02515 seconds
Time After: 0.02562 seconds
Time Before: 0.02583 seconds
Time After: 0.02597 seconds
Time Before: 0.02685 seconds
Time After: 0.02876 seconds
Time Taken: 0.00191 seconds
Time Before: 0.02604 seconds
Time After: 0.03284 seconds
Time Taken: 0.00679 seconds
Time Before: 0.04399 seconds
Time After: 0.04442 seconds
Time Before: 0.04772 seconds
Time After: 0.04894 seconds
Memory Before: 2,148.938 KB
Memory After: 2,148.797 KB
Time Before: 0.04328 seconds
Time After: 0.04919 seconds
Time Taken: 0.00591 seconds
Memory After: 2,261.820 KB
Time Before: 0.07192 seconds
Time After: 0.07206 seconds
Memory Before: 2,815.367 KB
Memory After: 2,815.883 KB
Time Before: 0.08988 seconds
Time After: 0.09110 seconds
Memory Before: 2,903.563 KB
Memory After: 2,904.156 KB
Time Before: 0.10825 seconds
Time After: 0.10847 seconds
Memory Before: 3,540.328 KB
Memory After: 3,540.758 KB
Time Before: 0.11141 seconds
Time After: 0.11322 seconds
Time Taken: 0.00181 seconds
Memory Before: 3,821.859 KB
Memory After: 3,823.547 KB
UPDATE session SET lastactivity = 1788946375, location = '/forums/private.php?do=newpm&explain=1&u=122765', badlocation = 1 WHERE sessionhash = '7fe2d67a1fab00498787d8dbbdf69797'
Time Before: 0.13436 seconds
Time After: 0.13481 seconds
Memory Before: 4,287.836 KB
Memory After: 4,288.047 KB
