Time Before: 0.00138 seconds
Time After: 0.00183 seconds
Time Before: 0.00190 seconds
Time After: 0.00235 seconds
Time Before: 0.00260 seconds
Time After: 0.00274 seconds
Time Before: 0.00351 seconds
Time After: 0.00580 seconds
Time Taken: 0.00229 seconds
Time Before: 0.00280 seconds
Time After: 0.00919 seconds
Time Taken: 0.00639 seconds
Time Before: 0.01103 seconds
Time After: 0.01149 seconds
Time Before: 0.01419 seconds
Time After: 0.01540 seconds
Time Before: 0.01043 seconds
Time After: 0.01567 seconds
Time Taken: 0.00524 seconds
Time Before: 0.02192 seconds
Time After: 0.02207 seconds
Time Before: 0.02431 seconds
Time After: 0.02551 seconds
Time Before: 0.02838 seconds
Time After: 0.02852 seconds
Time Before: 0.03046 seconds
Time After: 0.03202 seconds
Time Taken: 0.00156 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=122781', badlocation = 1 WHERE sessionhash = '7fe2d67a1fab00498787d8dbbdf69797'
Time Before: 0.04664 seconds
Time After: 0.04713 seconds
