Time Before: 0.00147 seconds
Time After: 0.00191 seconds
Time Before: 0.00198 seconds
Time After: 0.00249 seconds
Time Before: 0.00274 seconds
Time After: 0.00287 seconds
Time Before: 0.00362 seconds
Time After: 0.00659 seconds
Time Taken: 0.00297 seconds
Time Before: 0.00292 seconds
Time After: 0.00999 seconds
Time Taken: 0.00708 seconds
Time Before: 0.01204 seconds
Time After: 0.01250 seconds
Time Before: 0.01558 seconds
Time After: 0.01684 seconds
Time Before: 0.01140 seconds
Time After: 0.01702 seconds
Time Taken: 0.00562 seconds
Time Before: 0.02218 seconds
Time After: 0.02242 seconds
Time Before: 0.02443 seconds
Time After: 0.02566 seconds
End call of global.php: 0.027297973632812
Time Before: 0.02858 seconds
Time After: 0.02873 seconds
Time Before: 0.03079 seconds
Time After: 0.03223 seconds
SET lastactivity = 1788913216, location = '/forums/private.php?do=newpm&explain=1&u=122788', badlocation = 1
Time Before: 0.04513 seconds
Time After: 0.04564 seconds
Page generated in 0.044195890426636 seconds with 9 queries, spending 0.0088810920715332 doing MySQL queries and 0.035314798355103 doing PHP things.
