Time Before: 0.00136 seconds
Time After: 0.00184 seconds
Time Before: 0.00190 seconds
Time After: 0.00257 seconds
Time Taken: 0.00067 seconds
Time Before: 0.00282 seconds
Time After: 0.00299 seconds
Time Before: 0.00368 seconds
Time After: 0.00601 seconds
Time Taken: 0.00233 seconds
Time Before: 0.00304 seconds
Time After: 0.00940 seconds
Time Taken: 0.00636 seconds
Time Before: 0.01119 seconds
Time After: 0.01145 seconds
Time Before: 0.01396 seconds
Time After: 0.01533 seconds
Time Taken: 0.00137 seconds
Time Before: 0.01062 seconds
Time After: 0.01557 seconds
Time Taken: 0.00495 seconds
Time Before: 0.02130 seconds
Time After: 0.02152 seconds
Time Before: 0.02342 seconds
Time After: 0.02473 seconds
Time Taken: 0.00131 seconds
End call of global.php: 0.026350021362305
Time Before: 0.02749 seconds
Time After: 0.02769 seconds
Time Before: 0.02970 seconds
Time After: 0.03115 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=122793'
Time Before: 0.04530 seconds
Time After: 0.04569 seconds
Memory Before: 4,287.922 KB
Memory After: 4,288.164 KB
Page generated in 0.043941020965576 seconds with 9 queries, spending 0.0083897113800049 doing MySQL queries and 0.035551309585571 doing PHP things.
