Time Before: 0.01783 seconds
Time After: 0.02105 seconds
Time Taken: 0.00322 seconds
Time Before: 0.02114 seconds
Time After: 0.02194 seconds
Time Taken: 0.00081 seconds
Time Before: 0.02232 seconds
Time After: 0.02250 seconds
Time Before: 0.02342 seconds
Time After: 0.02583 seconds
Time Taken: 0.00241 seconds
Time Before: 0.02260 seconds
Time After: 0.03133 seconds
Time Taken: 0.00873 seconds
Time Before: 0.03733 seconds
Time After: 0.03758 seconds
Time Before: 0.04030 seconds
Time After: 0.04158 seconds
Memory Before: 2,148.938 KB
Memory After: 2,148.797 KB
Time Before: 0.03647 seconds
Time After: 0.04186 seconds
Time Taken: 0.00540 seconds
Memory After: 2,261.836 KB
Memory Used: 132.898 KB
Time Before: 0.06566 seconds
Time After: 0.06584 seconds
Memory Before: 2,815.383 KB
Memory After: 2,815.898 KB
Time Before: 0.57797 seconds
Time After: 0.57962 seconds
Time Taken: 0.00165 seconds
Memory Before: 2,903.578 KB
Memory After: 2,904.172 KB
Time Before: 0.58618 seconds
Time After: 0.58635 seconds
Memory Before: 3,540.344 KB
Memory After: 3,540.773 KB
Time Before: 0.58936 seconds
Time After: 0.59088 seconds
Time Taken: 0.00152 seconds
Memory Before: 3,821.875 KB
Memory After: 3,823.563 KB
UPDATE session SET lastactivity = 1788913372, location = '/forums/private.php?do=newpm&explain=1&u=122811', badlocation = 1 WHERE sessionhash = 'f13dd3a27df226bbe6e1fd6696c36073'
Time Before: 0.61093 seconds
Time After: 0.61124 seconds
Memory Before: 4,287.914 KB
Memory After: 4,288.125 KB
