Time Before: 0.01782 seconds
Time After: 0.02194 seconds
Time Taken: 0.00412 seconds
Time Before: 0.02201 seconds
Time After: 0.02274 seconds
Time Taken: 0.00073 seconds
Time Before: 0.02308 seconds
Time After: 0.02325 seconds
Time Before: 0.02402 seconds
Time After: 0.02610 seconds
Time Taken: 0.00208 seconds
Time Before: 0.02330 seconds
Time After: 0.03037 seconds
Time Taken: 0.00707 seconds
Time Before: 0.03689 seconds
Time After: 0.03730 seconds
Time Before: 0.04016 seconds
Time After: 0.04138 seconds
Time Before: 0.03627 seconds
Time After: 0.04168 seconds
Time Taken: 0.00540 seconds
Time Before: 0.07443 seconds
Time After: 0.07457 seconds
Time Before: 0.08998 seconds
Time After: 0.09119 seconds
Time Before: 0.10326 seconds
Time After: 0.10350 seconds
Time Before: 0.10659 seconds
Time After: 0.10802 seconds
UPDATE session SET lastactivity = 1776458526, location = '/forums/private.php?do=newpm&explain=1&u=122825', badlocation = 1 WHERE sessionhash = '0d59333b9979c57800f17621ab8164fa'
Time Before: 0.12943 seconds
Time After: 0.46802 seconds
Time Taken: 0.33859 seconds
Memory Before: 4,288.547 KB
Memory After: 4,288.758 KB
