Time Before: 0.00933 seconds
Time After: 0.01223 seconds
Time Taken: 0.00291 seconds
Time Before: 0.01235 seconds
Time After: 0.01357 seconds
Time Before: 0.01389 seconds
Time After: 0.01410 seconds
Time Before: 0.01498 seconds
Time After: 0.01733 seconds
Time Taken: 0.00235 seconds
Time Before: 0.01418 seconds
Time After: 0.02250 seconds
Time Taken: 0.00832 seconds
Time Before: 0.02714 seconds
Time After: 0.02763 seconds
Time Before: 0.03023 seconds
Time After: 0.03145 seconds
Time Before: 0.02636 seconds
Time After: 0.03172 seconds
Time Taken: 0.00536 seconds
Time Before: 0.04855 seconds
Time After: 0.04875 seconds
Time Before: 0.06866 seconds
Time After: 0.06994 seconds
End call of global.php: 0.07245397567749
Time Before: 0.07641 seconds
Time After: 0.07662 seconds
Time Before: 0.07931 seconds
Time After: 0.08114 seconds
Time Taken: 0.00183 seconds
SET lastactivity = 1789094942, location = '/forums/private.php?do=newpm&explain=1&u=122850', badlocation = 1
Time Before: 0.09855 seconds
Time After: 0.09892 seconds
Page generated in 0.097363948822021 seconds with 9 queries, spending 0.0093755722045898 doing MySQL queries and 0.087988376617432 doing PHP things.
