Time Before: 0.00159 seconds
Time After: 0.00218 seconds
Time Taken: 0.00059 seconds
Memory Before: 1,159.359 KB
Memory After: 1,184.477 KB
Time Before: 0.00229 seconds
Time After: 0.00291 seconds
Time Taken: 0.00062 seconds
Memory Before: 1,184.414 KB
Memory After: 1,185.422 KB
Time Before: 0.00317 seconds
Time After: 0.00330 seconds
Memory Before: 1,186.008 KB
Memory After: 1,186.531 KB
Time Before: 0.00422 seconds
Time After: 0.00646 seconds
Time Taken: 0.00224 seconds
Memory Before: 1,189.133 KB
Memory After: 1,190.055 KB
Time Before: 0.00338 seconds
Time After: 0.01124 seconds
Time Taken: 0.00786 seconds
Memory Before: 1,185.750 KB
Memory After: 2,266.781 KB
Time Before: 0.01570 seconds
Time After: 0.01611 seconds
Memory Before: 2,759.484 KB
Memory After: 2,760.102 KB
Time Before: 0.01885 seconds
Time After: 0.02117 seconds
Time Taken: 0.00233 seconds
Memory Before: 2,771.656 KB
Memory After: 2,771.516 KB
Time Before: 0.01454 seconds
Time After: 0.02143 seconds
Time Taken: 0.00689 seconds
Memory Before: 2,751.625 KB
Memory After: 2,884.547 KB
Time Before: 0.03132 seconds
Time After: 0.03145 seconds
Memory Before: 3,437.688 KB
Memory After: 3,438.203 KB
Time Before: 0.03388 seconds
Time After: 0.03511 seconds
Memory Before: 3,525.500 KB
Memory After: 3,526.094 KB
End call of global.php: 0.037581205368042
Time Before: 0.03878 seconds
Time After: 0.03891 seconds
Memory Before: 4,163.391 KB
Memory After: 4,163.820 KB
Time Before: 0.04087 seconds
Time After: 0.04320 seconds
Memory Before: 4,444.953 KB
Memory After: 4,446.641 KB
SET lastactivity = 1788990458, location = '/forums/private.php?do=newpm&explain=1&u=122853'
Time Before: 0.05882 seconds
Time After: 0.05909 seconds
Memory Before: 4,918.805 KB
Memory After: 4,919.031 KB
Page generated in 0.057638168334961 seconds with 9 queries, spending 0.0097992420196533 doing MySQL queries and 0.047838926315308 doing PHP things.
