Time Before: 0.00144 seconds
Time After: 0.00193 seconds
Time Before: 0.00200 seconds
Time After: 0.00249 seconds
Time Before: 0.00275 seconds
Time After: 0.00287 seconds
Time Before: 0.00370 seconds
Time After: 0.00635 seconds
Time Taken: 0.00265 seconds
Time Before: 0.00295 seconds
Time After: 0.01125 seconds
Time Taken: 0.00831 seconds
Time Before: 0.01354 seconds
Time After: 0.01395 seconds
Time Before: 0.01690 seconds
Time After: 0.01821 seconds
Time Taken: 0.00132 seconds
Time Before: 0.01279 seconds
Time After: 0.01847 seconds
Time Taken: 0.00568 seconds
Time Before: 0.02386 seconds
Time After: 0.02398 seconds
Time Before: 0.02595 seconds
Time After: 0.02717 seconds
End call of global.php: 0.02888298034668
Time Before: 0.03020 seconds
Time After: 0.03037 seconds
Time Before: 0.03236 seconds
Time After: 0.03378 seconds
SET lastactivity = 1788901229, location = '/forums/private.php?do=newpm&explain=1&u=122903'
Time Before: 0.04621 seconds
Time After: 0.04650 seconds
Page generated in 0.045305013656616 seconds with 9 queries, spending 0.008216381072998 doing MySQL queries and 0.037088632583618 doing PHP things.
