Time Before: 0.00963 seconds
Time After: 0.01353 seconds
Time Taken: 0.00390 seconds
Time Before: 0.01364 seconds
Time After: 0.01414 seconds
Time Before: 0.01440 seconds
Time After: 0.01454 seconds
Time Before: 0.01529 seconds
Time After: 0.01747 seconds
Time Taken: 0.00218 seconds
Time Before: 0.01462 seconds
Time After: 0.02168 seconds
Time Taken: 0.00706 seconds
Time Before: 0.02672 seconds
Time After: 0.02716 seconds
Time Before: 0.02850 seconds
Time After: 0.02987 seconds
Time Taken: 0.00137 seconds
Time Before: 0.02600 seconds
Time After: 0.03009 seconds
Time Taken: 0.00409 seconds
Time Before: 0.04588 seconds
Time After: 0.04603 seconds
Time Before: 0.05355 seconds
Time After: 0.05485 seconds
End call of global.php: 0.056677103042603
Time Before: 0.05957 seconds
Time After: 0.05979 seconds
Time Before: 0.06183 seconds
Time After: 0.06326 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=122915'
WHERE sessionhash = '39fd84efec1f1104044a97f8301439e1'
Time Before: 0.07921 seconds
Time After: 0.07954 seconds
Page generated in 0.078149080276489 seconds with 9 queries, spending 0.0080585479736328 doing MySQL queries and 0.070090532302856 doing PHP things.
