Time Before: 0.02935 seconds
Time After: 0.03556 seconds
Time Taken: 0.00621 seconds
Time Before: 0.03567 seconds
Time After: 0.03616 seconds
Time Before: 0.03646 seconds
Time After: 0.03663 seconds
Time Before: 0.03740 seconds
Time After: 0.03983 seconds
Time Taken: 0.00243 seconds
Time Before: 0.03668 seconds
Time After: 0.04410 seconds
Time Taken: 0.00742 seconds
Time Before: 0.05480 seconds
Time After: 0.05506 seconds
Time Before: 0.05778 seconds
Time After: 0.05937 seconds
Time Taken: 0.00159 seconds
Time Before: 0.05402 seconds
Time After: 0.05960 seconds
Time Taken: 0.00558 seconds
Time Before: 0.10669 seconds
Time After: 0.10685 seconds
Time Before: 0.12634 seconds
Time After: 0.12769 seconds
Time Taken: 0.00135 seconds
End call of global.php: 0.12992787361145
Time Before: 0.14316 seconds
Time After: 0.14340 seconds
Time Before: 0.14620 seconds
Time After: 0.14774 seconds
Time Taken: 0.00153 seconds
SET lastactivity = 1780640748, location = '/forums/private.php?do=newpm&explain=1&u=122956'
Time Before: 0.17006 seconds
Time After: 0.17035 seconds
Memory Before: 4,288.266 KB
Memory After: 4,288.492 KB
Page generated in 0.16910886764526 seconds with 9 queries, spending 0.0085136890411377 doing MySQL queries and 0.16059517860413 doing PHP things.
