Time Before: 0.00141 seconds
Time After: 0.00195 seconds
Time Taken: 0.00054 seconds
Time Before: 0.00202 seconds
Time After: 0.00244 seconds
Time Before: 0.00281 seconds
Time After: 0.00299 seconds
Time Before: 0.00389 seconds
Time After: 0.00692 seconds
Time Taken: 0.00304 seconds
Time Before: 0.00307 seconds
Time After: 0.01172 seconds
Time Taken: 0.00865 seconds
Time Before: 0.01370 seconds
Time After: 0.01394 seconds
Time Before: 0.01637 seconds
Time After: 0.01803 seconds
Time Taken: 0.00166 seconds
Time Before: 0.01298 seconds
Time After: 0.01827 seconds
Time Taken: 0.00529 seconds
Time Before: 0.02401 seconds
Time After: 0.02418 seconds
Time Before: 0.02658 seconds
Time After: 0.02785 seconds
Time Before: 0.03205 seconds
Time After: 0.03224 seconds
Time Before: 0.03522 seconds
Time After: 0.03691 seconds
Time Taken: 0.00169 seconds
UPDATE session SET lastactivity = 1782956252, location = '/forums/private.php?do=newpm&explain=1&u=122988', badlocation = 1 WHERE sessionhash = '90b3c67278b177629fe550ebf4d83bbe'
Time Before: 0.05089 seconds
Time After: 0.05128 seconds
