Time Before: 0.00136 seconds
Time After: 0.00187 seconds
Time Before: 0.00194 seconds
Time After: 0.00245 seconds
Time Before: 0.00270 seconds
Time After: 0.00281 seconds
Time Before: 0.00355 seconds
Time After: 0.00597 seconds
Time Taken: 0.00243 seconds
Time Before: 0.00286 seconds
Time After: 0.00933 seconds
Time Taken: 0.00647 seconds
Time Before: 0.01127 seconds
Time After: 0.01173 seconds
Time Before: 0.01501 seconds
Time After: 0.01626 seconds
Time Before: 0.01061 seconds
Time After: 0.01643 seconds
Time Taken: 0.00582 seconds
Time Before: 0.02140 seconds
Time After: 0.02167 seconds
Time Before: 0.02361 seconds
Time After: 0.02486 seconds
End call of global.php: 0.026478052139282
Time Before: 0.02855 seconds
Time After: 0.02873 seconds
Time Before: 0.03079 seconds
Time After: 0.03222 seconds
SET lastactivity = 1788897680, location = '/forums/private.php?do=newpm&explain=1&u=123008'
Time Before: 0.04459 seconds
Time After: 0.04499 seconds
Page generated in 0.043668031692505 seconds with 9 queries, spending 0.0083088874816895 doing MySQL queries and 0.035359144210815 doing PHP things.
