Time Before: 0.00842 seconds
Time After: 0.01175 seconds
Time Taken: 0.00333 seconds
Time Before: 0.01184 seconds
Time After: 0.01228 seconds
Time Before: 0.01251 seconds
Time After: 0.01264 seconds
Time Before: 0.01335 seconds
Time After: 0.01565 seconds
Time Taken: 0.00230 seconds
Time Before: 0.01269 seconds
Time After: 0.02015 seconds
Time Taken: 0.00745 seconds
Time Before: 0.02478 seconds
Time After: 0.02520 seconds
Time Before: 0.02763 seconds
Time After: 0.02886 seconds
Time Before: 0.02404 seconds
Time After: 0.02905 seconds
Time Taken: 0.00501 seconds
Time Before: 0.05313 seconds
Time After: 0.05328 seconds
Time Before: 0.06470 seconds
Time After: 0.06596 seconds
End call of global.php: 0.068315982818604
Time Before: 0.07201 seconds
Time After: 0.07222 seconds
Time Before: 0.07521 seconds
Time After: 0.07670 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=123016'
WHERE sessionhash = '295cc732df117534f65c11ae631a16f6'
Time Before: 0.09525 seconds
Time After: 0.09553 seconds
Memory Before: 4,287.922 KB
Memory After: 4,288.164 KB
Page generated in 0.094274997711182 seconds with 9 queries, spending 0.0079009532928467 doing MySQL queries and 0.086374044418335 doing PHP things.
