Time Before: 0.01411 seconds
Time After: 0.02249 seconds
Time Taken: 0.00838 seconds
Time Before: 0.02260 seconds
Time After: 0.02307 seconds
Time Before: 0.02334 seconds
Time After: 0.02346 seconds
Time Before: 0.02437 seconds
Time After: 0.02673 seconds
Time Taken: 0.00236 seconds
Time Before: 0.02355 seconds
Time After: 0.03250 seconds
Time Taken: 0.00895 seconds
Time Before: 0.04339 seconds
Time After: 0.04387 seconds
Time Before: 0.04644 seconds
Time After: 0.04766 seconds
Time Before: 0.04261 seconds
Time After: 0.04791 seconds
Time Taken: 0.00531 seconds
Time Before: 0.08710 seconds
Time After: 0.08731 seconds
Time Before: 0.10386 seconds
Time After: 0.10514 seconds
Time Before: 0.11661 seconds
Time After: 0.11677 seconds
Time Before: 0.11924 seconds
Time After: 0.12071 seconds
UPDATE session SET lastactivity = 1785408308, location = '/forums/private.php?do=newpm&explain=1&u=123018' WHERE sessionhash = 'dd14cf6af34df6bab38ac9fb3783395f'
Time Before: 0.13706 seconds
Time After: 0.13732 seconds
Memory Before: 4,289.063 KB
Memory After: 4,289.289 KB
