Time Before: 0.00252 seconds
Time After: 0.00336 seconds
Time Taken: 0.00083 seconds
Time Before: 0.00345 seconds
Time After: 0.00402 seconds
Time Taken: 0.00057 seconds
Time Before: 0.00426 seconds
Time After: 0.00442 seconds
Time Before: 0.00508 seconds
Time After: 0.00849 seconds
Time Taken: 0.00341 seconds
Time Before: 0.00447 seconds
Time After: 0.01233 seconds
Time Taken: 0.00786 seconds
Time Before: 0.01448 seconds
Time After: 0.01483 seconds
Time Before: 0.01733 seconds
Time After: 0.01865 seconds
Time Taken: 0.00132 seconds
Time Before: 0.01388 seconds
Time After: 0.01883 seconds
Time Taken: 0.00494 seconds
Time Before: 0.02372 seconds
Time After: 0.02394 seconds
Time Before: 0.02593 seconds
Time After: 0.02719 seconds
Time Before: 0.03009 seconds
Time After: 0.03025 seconds
Time Before: 0.03213 seconds
Time After: 0.03356 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=123051', badlocation = 1 WHERE sessionhash = '1b43d45bbaaa70ba8be59b846adc9cfa'
Time Before: 0.04594 seconds
Time After: 0.04622 seconds
Memory Before: 4,288.203 KB
Memory After: 4,288.430 KB
