Time Before: 0.00215 seconds
Time After: 0.00269 seconds
Time Taken: 0.00054 seconds
Time Before: 0.00276 seconds
Time After: 0.00329 seconds
Time Before: 0.00358 seconds
Time After: 0.00377 seconds
Time Before: 0.00463 seconds
Time After: 0.00732 seconds
Time Taken: 0.00269 seconds
Time Before: 0.00385 seconds
Time After: 0.01210 seconds
Time Taken: 0.00825 seconds
Time Before: 0.01397 seconds
Time After: 0.01437 seconds
Time Before: 0.01687 seconds
Time After: 0.01809 seconds
Memory Before: 2,148.938 KB
Memory After: 2,148.797 KB
Time Before: 0.01333 seconds
Time After: 0.01834 seconds
Time Taken: 0.00501 seconds
Memory After: 2,261.820 KB
Time Before: 0.02487 seconds
Time After: 0.02502 seconds
Memory Before: 2,815.367 KB
Memory After: 2,815.883 KB
Time Before: 0.02703 seconds
Time After: 0.02832 seconds
Memory Before: 2,903.563 KB
Memory After: 2,904.156 KB
Time Before: 0.03183 seconds
Time After: 0.03198 seconds
Memory Before: 3,540.328 KB
Memory After: 3,540.758 KB
Time Before: 0.03404 seconds
Time After: 0.03628 seconds
Time Taken: 0.00224 seconds
Memory Before: 3,821.859 KB
Memory After: 3,823.547 KB
UPDATE session SET lastactivity = 1788883680, location = '/forums/private.php?do=newpm&explain=1&u=123053', badlocation = 1 WHERE sessionhash = 'f13dd3a27df226bbe6e1fd6696c36073'
Time Before: 0.05200 seconds
Time After: 0.05238 seconds
Memory Before: 4,287.836 KB
Memory After: 4,288.047 KB
