Time Before: 0.00145 seconds
Time After: 0.00197 seconds
Time Taken: 0.00053 seconds
Time Before: 0.00205 seconds
Time After: 0.00295 seconds
Time Taken: 0.00090 seconds
Time Before: 0.00332 seconds
Time After: 0.00356 seconds
Time Before: 0.00420 seconds
Time After: 0.00696 seconds
Time Taken: 0.00276 seconds
Time Before: 0.00362 seconds
Time After: 0.01037 seconds
Time Taken: 0.00676 seconds
Time Before: 0.01243 seconds
Time After: 0.01267 seconds
Time Before: 0.01401 seconds
Time After: 0.01533 seconds
Time Taken: 0.00132 seconds
Time Before: 0.01179 seconds
Time After: 0.01551 seconds
Time Taken: 0.00372 seconds
Time Before: 0.02060 seconds
Time After: 0.02076 seconds
Time Before: 0.02273 seconds
Time After: 0.02397 seconds
End call of global.php: 0.025653123855591
Time Before: 0.02684 seconds
Time After: 0.02700 seconds
Time Before: 0.02894 seconds
Time After: 0.03042 seconds
SET lastactivity = 1789148409, location = '/forums/private.php?do=newpm&explain=1&u=12310', badlocation = 1
Time Before: 0.04262 seconds
Time After: 0.04319 seconds
Time Taken: 0.00057 seconds
Memory Before: 4,911.453 KB
Memory After: 4,911.664 KB
Page generated in 0.041736125946045 seconds with 9 queries, spending 0.0090782642364502 doing MySQL queries and 0.032657861709595 doing PHP things.
