Time Before: 0.01392 seconds
Time After: 0.01902 seconds
Time Taken: 0.00510 seconds
Time Before: 0.01914 seconds
Time After: 0.02049 seconds
Time Taken: 0.00135 seconds
Time Before: 0.02086 seconds
Time After: 0.02102 seconds
Time Before: 0.02187 seconds
Time After: 0.02598 seconds
Time Taken: 0.00412 seconds
Time Before: 0.02110 seconds
Time After: 0.03040 seconds
Time Taken: 0.00930 seconds
Time Before: 0.03637 seconds
Time After: 0.03661 seconds
Time Before: 0.03939 seconds
Time After: 0.04068 seconds
Memory Before: 2,148.820 KB
Memory After: 2,148.680 KB
Time Before: 0.03566 seconds
Time After: 0.04092 seconds
Time Taken: 0.00526 seconds
Memory After: 2,261.703 KB
Time Before: 0.07382 seconds
Time After: 0.07399 seconds
Memory Before: 2,815.281 KB
Memory After: 2,815.797 KB
Time Before: 0.09048 seconds
Time After: 0.09252 seconds
Time Taken: 0.00204 seconds
Memory Before: 2,903.477 KB
Memory After: 2,904.070 KB
End call of global.php: 0.095235109329224
Time Before: 0.10197 seconds
Time After: 0.10211 seconds
Memory Before: 3,540.234 KB
Memory After: 3,540.664 KB
Time Before: 0.10498 seconds
Time After: 0.10642 seconds
Memory Before: 3,821.766 KB
Memory After: 3,823.453 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=123132', badlocation = 1
Time Before: 0.12305 seconds
Time After: 0.12329 seconds
Memory Before: 4,287.469 KB
Memory After: 4,287.695 KB
Page generated in 0.12211608886719 seconds with 9 queries, spending 0.011183023452759 doing MySQL queries and 0.11093306541443 doing PHP things.
