Time Before: 0.02037 seconds
Time After: 0.02628 seconds
Time Taken: 0.00591 seconds
Time Before: 0.02639 seconds
Time After: 0.02689 seconds
Time Before: 0.02742 seconds
Time After: 0.02761 seconds
Time Before: 0.02847 seconds
Time After: 0.03074 seconds
Time Taken: 0.00227 seconds
Time Before: 0.02769 seconds
Time After: 0.03462 seconds
Time Taken: 0.00693 seconds
Time Before: 0.04083 seconds
Time After: 0.04123 seconds
Time Before: 0.04364 seconds
Time After: 0.04488 seconds
Time Before: 0.04011 seconds
Time After: 0.04508 seconds
Time Taken: 0.00496 seconds
Time Before: 0.07658 seconds
Time After: 0.07678 seconds
Time Before: 1.73080 seconds
Time After: 1.73298 seconds
Time Taken: 0.00218 seconds
Time Before: 1.74364 seconds
Time After: 1.74387 seconds
Time Before: 1.74657 seconds
Time After: 1.74818 seconds
Time Taken: 0.00162 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=123145' WHERE sessionhash = '0072f2714e5608fd7a8a8d7024a3e041'
Time Before: 1.77089 seconds
Time After: 1.77112 seconds
Memory Before: 4,287.922 KB
Memory After: 4,288.164 KB
