Time Before: 0.00484 seconds
Time After: 0.00611 seconds
Time Before: 0.00621 seconds
Time After: 0.00661 seconds
Time Before: 0.00686 seconds
Time After: 0.00701 seconds
Time Before: 0.00792 seconds
Time After: 0.01105 seconds
Time Taken: 0.00313 seconds
Time Before: 0.00709 seconds
Time After: 0.01452 seconds
Time Taken: 0.00742 seconds
Time Before: 0.01725 seconds
Time After: 0.01743 seconds
Time Before: 0.01880 seconds
Time After: 0.02049 seconds
Time Taken: 0.00169 seconds
Time Before: 0.01662 seconds
Time After: 0.02071 seconds
Time Taken: 0.00409 seconds
Time Before: 0.02793 seconds
Time After: 0.02808 seconds
Time Before: 0.03071 seconds
Time After: 0.03225 seconds
Time Taken: 0.00154 seconds
End call of global.php: 0.034879922866821
Time Before: 0.03684 seconds
Time After: 0.03704 seconds
Time Before: 0.03993 seconds
Time After: 0.04141 seconds
SET lastactivity = 1783072018, location = '/forums/private.php?do=newpm&explain=1&u=12315', badlocation = 1
Time Before: 0.05488 seconds
Time After: 0.05702 seconds
Time Taken: 0.00214 seconds
Memory Before: 4,288.594 KB
Memory After: 4,288.805 KB
Page generated in 0.053929805755615 seconds with 9 queries, spending 0.011071920394897 doing MySQL queries and 0.042857885360718 doing PHP things.
