Time Before: 0.00876 seconds
Time After: 0.01208 seconds
Time Taken: 0.00332 seconds
Time Before: 0.01218 seconds
Time After: 0.01258 seconds
Time Before: 0.01280 seconds
Time After: 0.01293 seconds
Time Before: 0.01367 seconds
Time After: 0.01600 seconds
Time Taken: 0.00233 seconds
Time Before: 0.01299 seconds
Time After: 0.02063 seconds
Time Taken: 0.00764 seconds
Time Before: 0.02461 seconds
Time After: 0.02481 seconds
Time Before: 0.02629 seconds
Time After: 0.02748 seconds
Time Taken: 0.00118 seconds
Time Before: 0.02380 seconds
Time After: 0.02769 seconds
Time Taken: 0.00389 seconds
Time Before: 0.04361 seconds
Time After: 0.04392 seconds
Time Before: 0.05232 seconds
Time After: 0.05359 seconds
End call of global.php: 0.056375980377197
Time Before: 0.05983 seconds
Time After: 0.06003 seconds
Time Before: 0.06332 seconds
Time After: 0.06477 seconds
SET lastactivity = 1784803300, location = '/forums/private.php?do=newpm&explain=1&u=123177', badlocation = 1
Time Before: 0.08128 seconds
Time After: 0.08156 seconds
Memory Before: 4,288.547 KB
Memory After: 4,288.758 KB
Page generated in 0.080358982086182 seconds with 9 queries, spending 0.0077459812164307 doing MySQL queries and 0.072613000869751 doing PHP things.
