Time Before: 0.01996 seconds
Time After: 0.03471 seconds
Time Taken: 0.01476 seconds
Time Before: 0.03483 seconds
Time After: 0.03527 seconds
Time Before: 0.03551 seconds
Time After: 0.03565 seconds
Time Before: 0.03653 seconds
Time After: 0.03920 seconds
Time Taken: 0.00267 seconds
Time Before: 0.03573 seconds
Time After: 0.04468 seconds
Time Taken: 0.00895 seconds
Time Before: 0.05651 seconds
Time After: 0.05690 seconds
Time Before: 0.05939 seconds
Time After: 0.06067 seconds
Time Before: 0.05572 seconds
Time After: 0.06092 seconds
Time Taken: 0.00520 seconds
Time Before: 0.09538 seconds
Time After: 0.09552 seconds
Time Before: 0.30801 seconds
Time After: 0.30940 seconds
Time Taken: 0.00139 seconds
Time Before: 0.32021 seconds
Time After: 0.32036 seconds
Time Before: 0.32297 seconds
Time After: 0.32444 seconds
UPDATE session SET lastactivity = 1776660099, location = '/forums/private.php?do=newpm&explain=1&u=123182', badlocation = 1 WHERE sessionhash = '7f12e449499bf5aa31d8d04cb08a0450'
Time Before: 0.34345 seconds
Time After: 0.34375 seconds
Memory Before: 4,288.547 KB
Memory After: 4,288.758 KB
