Time Before: 0.02885 seconds
Time After: 0.03937 seconds
Time Taken: 0.01052 seconds
Time Before: 0.03949 seconds
Time After: 0.04000 seconds
Time Before: 0.04028 seconds
Time After: 0.04046 seconds
Time Before: 0.04129 seconds
Time After: 0.04394 seconds
Time Taken: 0.00265 seconds
Time Before: 0.04052 seconds
Time After: 0.04826 seconds
Time Taken: 0.00774 seconds
Time Before: 0.05615 seconds
Time After: 0.05656 seconds
Time Before: 0.05901 seconds
Time After: 0.06017 seconds
Time Taken: 0.00116 seconds
Time Before: 0.05539 seconds
Time After: 0.06039 seconds
Time Taken: 0.00500 seconds
Time Before: 0.11311 seconds
Time After: 0.11329 seconds
Time Before: 0.13471 seconds
Time After: 0.13596 seconds
Time Before: 0.14582 seconds
Time After: 0.14599 seconds
Time Before: 0.14830 seconds
Time After: 0.14974 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=123196' WHERE sessionhash = 'f0a2de90bc45baf36aaf71071f1bfe42'
Time Before: 0.16722 seconds
Time After: 0.16749 seconds
Memory Before: 4,287.922 KB
Memory After: 4,288.164 KB
