Time Before: 0.00182 seconds
Time After: 0.00229 seconds
Time Before: 0.00236 seconds
Time After: 0.00277 seconds
Time Before: 0.00311 seconds
Time After: 0.00325 seconds
Time Before: 0.00422 seconds
Time After: 0.00703 seconds
Time Taken: 0.00281 seconds
Time Before: 0.00333 seconds
Time After: 0.01188 seconds
Time Taken: 0.00855 seconds
Time Before: 0.01401 seconds
Time After: 0.01447 seconds
Time Before: 0.01759 seconds
Time After: 0.01887 seconds
Time Before: 0.01331 seconds
Time After: 0.01913 seconds
Time Taken: 0.00582 seconds
Time Before: 0.02680 seconds
Time After: 0.02699 seconds
Time Before: 0.02936 seconds
Time After: 0.03065 seconds
Time Before: 0.03381 seconds
Time After: 0.03399 seconds
Time Before: 0.03697 seconds
Time After: 0.03841 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=123234', badlocation = 1 WHERE sessionhash = 'f13dd3a27df226bbe6e1fd6696c36073'
Time Before: 0.05189 seconds
Time After: 0.05244 seconds
Time Taken: 0.00055 seconds
