Time Before: 0.00710 seconds
Time After: 0.01108 seconds
Time Taken: 0.00399 seconds
Time Before: 0.01121 seconds
Time After: 0.01167 seconds
Time Before: 0.01194 seconds
Time After: 0.01210 seconds
Time Before: 0.01303 seconds
Time After: 0.01537 seconds
Time Taken: 0.00234 seconds
Time Before: 0.01218 seconds
Time After: 0.01885 seconds
Time Taken: 0.00667 seconds
Time Before: 0.02207 seconds
Time After: 0.02241 seconds
Time Before: 0.02500 seconds
Time After: 0.02621 seconds
Time Before: 0.02147 seconds
Time After: 0.02649 seconds
Time Taken: 0.00502 seconds
Time Before: 0.04850 seconds
Time After: 0.04866 seconds
Time Before: 0.05686 seconds
Time After: 0.05855 seconds
Time Taken: 0.00169 seconds
End call of global.php: 0.061050891876221
Time Before: 0.06528 seconds
Time After: 0.06543 seconds
Time Before: 0.06786 seconds
Time After: 0.06932 seconds
SET lastactivity = 1783031983, location = '/forums/private.php?do=newpm&explain=1&u=123242', badlocation = 1
Time Before: 0.08620 seconds
Time After: 0.08654 seconds
Memory Before: 4,288.547 KB
Memory After: 4,288.758 KB
Page generated in 0.085125923156738 seconds with 9 queries, spending 0.0083248615264893 doing MySQL queries and 0.076801061630249 doing PHP things.
