Time Before: 0.00133 seconds
Time After: 0.00181 seconds
Time Before: 0.00188 seconds
Time After: 0.00246 seconds
Time Taken: 0.00059 seconds
Time Before: 0.00270 seconds
Time After: 0.00281 seconds
Time Before: 0.00352 seconds
Time After: 0.00587 seconds
Time Taken: 0.00235 seconds
Time Before: 0.00286 seconds
Time After: 0.00932 seconds
Time Taken: 0.00646 seconds
Time Before: 0.01131 seconds
Time After: 0.01152 seconds
Time Before: 0.01380 seconds
Time After: 0.01516 seconds
Time Taken: 0.00135 seconds
Time Before: 0.01066 seconds
Time After: 0.01534 seconds
Time Taken: 0.00468 seconds
Time Before: 0.02240 seconds
Time After: 0.02261 seconds
Time Before: 0.02489 seconds
Time After: 0.02616 seconds
End call of global.php: 0.027895927429199
Time Before: 0.02918 seconds
Time After: 0.02943 seconds
Time Before: 0.03154 seconds
Time After: 0.03301 seconds
SET lastactivity = 1784817748, location = '/forums/private.php?do=newpm&explain=1&u=123276', badlocation = 1
Time Before: 0.04558 seconds
Time After: 0.04585 seconds
Page generated in 0.04466700553894 seconds with 9 queries, spending 0.0080857276916504 doing MySQL queries and 0.03658127784729 doing PHP things.
