Time Before: 0.00157 seconds
Time After: 0.00239 seconds
Time Taken: 0.00081 seconds
Time Before: 0.00249 seconds
Time After: 0.00315 seconds
Time Taken: 0.00066 seconds
Time Before: 0.00338 seconds
Time After: 0.00356 seconds
Time Before: 0.00437 seconds
Time After: 0.00687 seconds
Time Taken: 0.00250 seconds
Time Before: 0.00361 seconds
Time After: 0.01124 seconds
Time Taken: 0.00763 seconds
Time Before: 0.01384 seconds
Time After: 0.01437 seconds
Time Before: 0.01746 seconds
Time After: 0.01873 seconds
Time Before: 0.01315 seconds
Time After: 0.01890 seconds
Time Taken: 0.00575 seconds
Time Before: 0.02410 seconds
Time After: 0.02443 seconds
Time Before: 0.02673 seconds
Time After: 0.02797 seconds
Time Before: 0.03217 seconds
Time After: 0.03235 seconds
Time Before: 0.03449 seconds
Time After: 0.03595 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=123280' WHERE sessionhash = '7fe2d67a1fab00498787d8dbbdf69797'
Time Before: 0.04861 seconds
Time After: 0.04894 seconds
