Time Before: 0.01047 seconds
Time After: 0.01401 seconds
Time Taken: 0.00353 seconds
Time Before: 0.01412 seconds
Time After: 0.01469 seconds
Time Taken: 0.00058 seconds
Time Before: 0.01523 seconds
Time After: 0.01567 seconds
Time Before: 0.01681 seconds
Time After: 0.01913 seconds
Time Taken: 0.00232 seconds
Time Before: 0.01574 seconds
Time After: 0.02352 seconds
Time Taken: 0.00778 seconds
Time Before: 0.02971 seconds
Time After: 0.02992 seconds
Time Before: 0.03231 seconds
Time After: 0.03353 seconds
Time Before: 0.02907 seconds
Time After: 0.03379 seconds
Time Taken: 0.00471 seconds
Time Before: 0.05238 seconds
Time After: 0.05255 seconds
Time Before: 0.06500 seconds
Time After: 0.06624 seconds
End call of global.php: 0.068341970443726
Time Before: 0.07600 seconds
Time After: 0.07618 seconds
Time Before: 0.07926 seconds
Time After: 0.08076 seconds
Time Taken: 0.00150 seconds
SET lastactivity = 1772952659, location = '/forums/private.php?do=newpm&explain=1&u=123326', badlocation = 1
WHERE sessionhash = 'a1024cf3a534e5ec94f7248e61d8a1ae'
Time Before: 0.09731 seconds
Time After: 0.09763 seconds
Memory Before: 4,912.320 KB
Memory After: 4,912.531 KB
Page generated in 0.096245050430298 seconds with 9 queries, spending 0.0081567764282227 doing MySQL queries and 0.088088274002075 doing PHP things.
