Time Before: 0.00198 seconds
Time After: 0.00258 seconds
Time Taken: 0.00060 seconds
Time Before: 0.00268 seconds
Time After: 0.00307 seconds
Time Before: 0.00330 seconds
Time After: 0.00344 seconds
Time Before: 0.00429 seconds
Time After: 0.00698 seconds
Time Taken: 0.00269 seconds
Time Before: 0.00352 seconds
Time After: 0.01286 seconds
Time Taken: 0.00934 seconds
Time Before: 0.01552 seconds
Time After: 0.01591 seconds
Time Before: 0.01868 seconds
Time After: 0.01992 seconds
Time Before: 0.01472 seconds
Time After: 0.02012 seconds
Time Taken: 0.00541 seconds
Time Before: 0.02591 seconds
Time After: 0.02604 seconds
Time Before: 0.02791 seconds
Time After: 0.02918 seconds
End call of global.php: 0.031893968582153
Time Before: 0.03350 seconds
Time After: 0.03385 seconds
Time Before: 0.03699 seconds
Time After: 0.03849 seconds
Time Taken: 0.00150 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=123408'
Time Before: 0.05484 seconds
Time After: 0.05510 seconds
Memory Before: 4,911.586 KB
Memory After: 4,911.828 KB
Page generated in 0.053900957107544 seconds with 9 queries, spending 0.0083677768707275 doing MySQL queries and 0.045533180236816 doing PHP things.
