Time Before: 0.00165 seconds
Time After: 0.00217 seconds
Time Before: 0.00227 seconds
Time After: 0.00337 seconds
Time Taken: 0.00110 seconds
Time Before: 0.00395 seconds
Time After: 0.00417 seconds
Time Before: 0.00530 seconds
Time After: 0.00915 seconds
Time Taken: 0.00384 seconds
Time Before: 0.00424 seconds
Time After: 0.01312 seconds
Time Taken: 0.00889 seconds
Time Before: 0.01554 seconds
Time After: 0.01602 seconds
Time Before: 0.01867 seconds
Time After: 0.02016 seconds
Time Before: 0.01479 seconds
Time After: 0.02036 seconds
Time Taken: 0.00557 seconds
Time Before: 0.02563 seconds
Time After: 0.02584 seconds
Time Before: 0.02826 seconds
Time After: 0.02949 seconds
Time Before: 0.03238 seconds
Time After: 0.03255 seconds
Time Before: 0.03469 seconds
Time After: 0.03613 seconds
UPDATE session SET lastactivity = 1772859172, location = '/forums/private.php?do=newpm&explain=1&u=123410', badlocation = 1 WHERE sessionhash = '05469e5b46550d3cbf9ccd27256b5c39'
Time Before: 0.05040 seconds
Time After: 0.05069 seconds
