Time Before: 0.00140 seconds
Time After: 0.00200 seconds
Time Taken: 0.00060 seconds
Time Before: 0.00207 seconds
Time After: 0.00255 seconds
Time Before: 0.00282 seconds
Time After: 0.00295 seconds
Time Before: 0.00366 seconds
Time After: 0.00680 seconds
Time Taken: 0.00314 seconds
Time Before: 0.00300 seconds
Time After: 0.01019 seconds
Time Taken: 0.00719 seconds
Time Before: 0.01213 seconds
Time After: 0.01250 seconds
Time Before: 0.01484 seconds
Time After: 0.01611 seconds
Time Before: 0.01157 seconds
Time After: 0.01628 seconds
Time Taken: 0.00471 seconds
Time Before: 0.02165 seconds
Time After: 0.02179 seconds
Time Before: 0.02391 seconds
Time After: 0.02518 seconds
Time Before: 0.02820 seconds
Time After: 0.02834 seconds
Time Before: 0.03029 seconds
Time After: 0.03169 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=123490', badlocation = 1 WHERE sessionhash = '7ca6ab718f0d2129a0db1a6bd7e3c55b'
Time Before: 0.04735 seconds
Time After: 0.04775 seconds
Memory Before: 4,911.867 KB
Memory After: 4,912.094 KB
