Time Before: 0.00169 seconds
Time After: 0.00224 seconds
Time Taken: 0.00055 seconds
Time Before: 0.00236 seconds
Time After: 0.00365 seconds
Time Before: 0.00393 seconds
Time After: 0.00408 seconds
Time Before: 0.00476 seconds
Time After: 0.00765 seconds
Time Taken: 0.00290 seconds
Time Before: 0.00413 seconds
Time After: 0.01183 seconds
Time Taken: 0.00770 seconds
Time Before: 0.01391 seconds
Time After: 0.01435 seconds
Time Before: 0.01699 seconds
Time After: 0.01830 seconds
Time Taken: 0.00131 seconds
Time Before: 0.01315 seconds
Time After: 0.01854 seconds
Time Taken: 0.00539 seconds
Time Before: 0.02425 seconds
Time After: 0.02442 seconds
Time Before: 0.02678 seconds
Time After: 0.02822 seconds
Time Before: 0.03194 seconds
Time After: 0.03221 seconds
Time Before: 0.03441 seconds
Time After: 0.03589 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=123512' WHERE sessionhash = 'dd14cf6af34df6bab38ac9fb3783395f'
Time Before: 0.04855 seconds
Time After: 0.04886 seconds
