Time Before: 0.00134 seconds
Time After: 0.00187 seconds
Time Taken: 0.00053 seconds
Memory Before: 1,159.359 KB
Memory After: 1,184.477 KB
Time Before: 0.00193 seconds
Time After: 0.00256 seconds
Time Taken: 0.00062 seconds
Memory Before: 1,184.414 KB
Memory After: 1,185.422 KB
Time Before: 0.00286 seconds
Time After: 0.00298 seconds
Memory Before: 1,186.008 KB
Memory After: 1,186.531 KB
Time Before: 0.00371 seconds
Time After: 0.00618 seconds
Time Taken: 0.00247 seconds
Memory Before: 1,189.133 KB
Memory After: 1,190.055 KB
Time Before: 0.00303 seconds
Time After: 0.00955 seconds
Time Taken: 0.00652 seconds
Memory Before: 1,185.750 KB
Memory After: 2,266.781 KB
Time Before: 0.01151 seconds
Time After: 0.01190 seconds
Memory Before: 2,759.484 KB
Memory After: 2,760.102 KB
Time Before: 0.01495 seconds
Time After: 0.01613 seconds
Time Taken: 0.00118 seconds
Memory Before: 2,771.656 KB
Memory After: 2,771.516 KB
Time Before: 0.01090 seconds
Time After: 0.01631 seconds
Time Taken: 0.00541 seconds
Memory Before: 2,751.625 KB
Memory After: 2,884.547 KB
Time Before: 0.02122 seconds
Time After: 0.02135 seconds
Memory Before: 3,437.688 KB
Memory After: 3,438.203 KB
Time Before: 0.02331 seconds
Time After: 0.02455 seconds
Memory Before: 3,525.500 KB
Memory After: 3,526.094 KB
Time Before: 0.02752 seconds
Time After: 0.02769 seconds
Memory Before: 4,163.391 KB
Memory After: 4,163.820 KB
Time Before: 0.02977 seconds
Time After: 0.03121 seconds
Memory Before: 4,444.953 KB
Memory After: 4,446.641 KB
UPDATE session SET lastactivity = 1785284665, location = '/forums/private.php?do=newpm&explain=1&u=123527' WHERE sessionhash = '1bdac016e56aac80b5f324b5c0ae82e4'
Time Before: 0.04788 seconds
Time After: 0.04813 seconds
Memory Before: 4,918.805 KB
Memory After: 4,919.031 KB
