Time Before: 0.01495 seconds
Time After: 0.02058 seconds
Time Taken: 0.00564 seconds
Memory Before: 1,246.250 KB
Memory After: 1,273.055 KB
Time Before: 0.02069 seconds
Time After: 0.02114 seconds
Memory Before: 1,273.016 KB
Memory After: 1,273.992 KB
Time Before: 0.02135 seconds
Time After: 0.02152 seconds
Memory Before: 1,274.633 KB
Memory After: 1,275.156 KB
Time Before: 0.02228 seconds
Time After: 0.02450 seconds
Time Taken: 0.00222 seconds
Memory Before: 1,278.023 KB
Memory After: 1,278.945 KB
Time Before: 0.02160 seconds
Time After: 0.02862 seconds
Time Taken: 0.00702 seconds
Memory Before: 1,274.438 KB
Memory After: 2,355.672 KB
Memory Used: 1,081.234 KB
Time Before: 0.03746 seconds
Time After: 0.03786 seconds
Memory Before: 2,895.938 KB
Memory After: 2,896.555 KB
Time Before: 0.04058 seconds
Time After: 0.04176 seconds
Memory Before: 2,908.266 KB
Memory After: 2,908.125 KB
Time Before: 0.03672 seconds
Time After: 0.04197 seconds
Time Taken: 0.00525 seconds
Memory Before: 2,888.664 KB
Memory After: 3,021.180 KB
Memory Used: 132.516 KB
Time Before: 0.08808 seconds
Time After: 0.08823 seconds
Memory Before: 3,655.820 KB
Memory After: 3,656.336 KB
Time Before: 0.14551 seconds
Time After: 0.14682 seconds
Time Taken: 0.00131 seconds
Memory Before: 4,133.383 KB
Memory After: 4,133.977 KB
Time Before: 0.16922 seconds
Time After: 0.16939 seconds
Memory Before: 5,197.555 KB
Memory After: 5,325.898 KB
Time Before: 0.17452 seconds
Time After: 0.17597 seconds
Memory Before: 5,481.250 KB
Memory After: 5,610.852 KB
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=123548', badlocation = 1 WHERE sessionhash = 'fb8546df1d172120a5a514bbe0406f9a'
Time Before: 0.20474 seconds
Time After: 0.20501 seconds
Memory Before: 5,998.641 KB
Memory After: 5,998.859 KB
