Time Before: 0.00803 seconds
Time After: 0.00956 seconds
Time Taken: 0.00153 seconds
Time Before: 0.00966 seconds
Time After: 0.01021 seconds
Time Taken: 0.00055 seconds
Time Before: 0.01049 seconds
Time After: 0.01066 seconds
Time Before: 0.01143 seconds
Time After: 0.01363 seconds
Time Taken: 0.00220 seconds
Time Before: 0.01073 seconds
Time After: 0.01819 seconds
Time Taken: 0.00746 seconds
Time Before: 0.02215 seconds
Time After: 0.02239 seconds
Time Before: 0.02497 seconds
Time After: 0.02636 seconds
Time Taken: 0.00139 seconds
Time Before: 0.02143 seconds
Time After: 0.02665 seconds
Time Taken: 0.00523 seconds
Time Before: 0.04111 seconds
Time After: 0.04128 seconds
Time Before: 0.05112 seconds
Time After: 0.05237 seconds
Time Before: 0.05899 seconds
Time After: 0.05919 seconds
Time Before: 0.06195 seconds
Time After: 0.06348 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=12360', badlocation = 1 WHERE sessionhash = '5dcfbb55b5add1e7cfb509ae0e835a95'
Time Before: 0.08379 seconds
Time After: 0.08410 seconds
Memory Before: 4,911.109 KB
Memory After: 4,911.336 KB
