Time Before: 0.01084 seconds
Time After: 0.01775 seconds
Time Taken: 0.00692 seconds
Time Before: 0.01786 seconds
Time After: 0.01938 seconds
Time Taken: 0.00153 seconds
Time Before: 0.01967 seconds
Time After: 0.01986 seconds
Time Before: 0.02067 seconds
Time After: 0.02322 seconds
Time Taken: 0.00254 seconds
Time Before: 0.01993 seconds
Time After: 0.02716 seconds
Time Taken: 0.00723 seconds
Time Before: 0.03391 seconds
Time After: 0.03411 seconds
Time Before: 0.03637 seconds
Time After: 0.03763 seconds
Time Before: 0.03327 seconds
Time After: 0.03780 seconds
Time Taken: 0.00453 seconds
Time Before: 0.05568 seconds
Time After: 0.05589 seconds
Time Before: 0.07235 seconds
Time After: 0.07360 seconds
Time Before: 0.08067 seconds
Time After: 0.08080 seconds
Time Before: 0.08297 seconds
Time After: 0.08437 seconds
UPDATE session SET lastactivity = 1776685149, location = '/forums/private.php?do=newpm&explain=1&u=123602', badlocation = 1 WHERE sessionhash = '7f12e449499bf5aa31d8d04cb08a0450'
Time Before: 0.10124 seconds
Time After: 0.10172 seconds
