Time Before: 0.01734 seconds
Time After: 0.02395 seconds
Time Taken: 0.00660 seconds
Memory Before: 1,246.250 KB
Memory After: 1,273.055 KB
Time Before: 0.02405 seconds
Time After: 0.02461 seconds
Time Taken: 0.00056 seconds
Memory Before: 1,273.016 KB
Memory After: 1,273.992 KB
Time Before: 0.02522 seconds
Time After: 0.02567 seconds
Memory Before: 1,274.633 KB
Memory After: 1,275.156 KB
Time Before: 0.02680 seconds
Time After: 0.02874 seconds
Time Taken: 0.00194 seconds
Memory Before: 1,278.023 KB
Memory After: 1,278.945 KB
Time Before: 0.02573 seconds
Time After: 0.03324 seconds
Time Taken: 0.00751 seconds
Memory Before: 1,274.438 KB
Memory After: 2,355.672 KB
Memory Used: 1,081.234 KB
Time Before: 0.04329 seconds
Time After: 0.04368 seconds
Memory Before: 2,895.938 KB
Memory After: 2,896.555 KB
Time Before: 0.04645 seconds
Time After: 0.04766 seconds
Memory Before: 2,908.383 KB
Memory After: 2,908.242 KB
Time Before: 0.04248 seconds
Time After: 0.04785 seconds
Time Taken: 0.00537 seconds
Memory Before: 2,888.664 KB
Memory After: 3,021.297 KB
Memory Used: 132.633 KB
Time Before: 0.09700 seconds
Time After: 0.09718 seconds
Memory Before: 3,655.813 KB
Memory After: 3,656.328 KB
Time Before: 0.15882 seconds
Time After: 0.16010 seconds
Memory Before: 4,133.500 KB
Memory After: 4,134.094 KB
Time Before: 0.18803 seconds
Time After: 0.18824 seconds
Memory Before: 5,197.727 KB
Memory After: 5,326.070 KB
Time Before: 0.19500 seconds
Time After: 0.19645 seconds
Memory Before: 5,481.406 KB
Memory After: 5,611.008 KB
UPDATE session SET lastactivity = 1772651506, location = '/forums/private.php?do=newpm&explain=1&u=123624', badlocation = 1 WHERE sessionhash = '600503b925d08d481e162d46884ab830'
Time Before: 0.22345 seconds
Time After: 0.22373 seconds
Memory Before: 5,998.219 KB
Memory After: 5,998.430 KB
