Time Before: 0.00924 seconds
Time After: 0.01242 seconds
Time Taken: 0.00318 seconds
Time Before: 0.01251 seconds
Time After: 0.01294 seconds
Time Before: 0.01318 seconds
Time After: 0.01330 seconds
Time Before: 0.01417 seconds
Time After: 0.01671 seconds
Time Taken: 0.00254 seconds
Time Before: 0.01337 seconds
Time After: 0.02017 seconds
Time Taken: 0.00680 seconds
Time Before: 0.02441 seconds
Time After: 0.02484 seconds
Time Before: 0.02775 seconds
Time After: 0.02891 seconds
Time Taken: 0.00116 seconds
Memory Before: 2,148.820 KB
Memory After: 2,148.680 KB
Time Before: 0.02381 seconds
Time After: 0.02908 seconds
Time Taken: 0.00527 seconds
Memory After: 2,261.703 KB
Time Before: 0.04488 seconds
Time After: 0.04500 seconds
Memory Before: 2,815.281 KB
Memory After: 2,815.797 KB
Time Before: 0.05081 seconds
Time After: 0.05206 seconds
Memory Before: 2,903.477 KB
Memory After: 2,904.070 KB
End call of global.php: 0.054531097412109
Time Before: 0.05893 seconds
Time After: 0.05917 seconds
Memory Before: 3,540.234 KB
Memory After: 3,540.664 KB
Time Before: 0.06152 seconds
Time After: 0.06299 seconds
Memory Before: 3,821.766 KB
Memory After: 3,823.453 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=123653'
Time Before: 0.07739 seconds
Time After: 0.07821 seconds
Time Taken: 0.00082 seconds
Memory Before: 4,287.188 KB
Memory After: 4,287.430 KB
Page generated in 0.076061010360718 seconds with 9 queries, spending 0.0085806846618652 doing MySQL queries and 0.067480325698853 doing PHP things.
