Time Before: 0.00559 seconds
Time After: 0.00677 seconds
Time Taken: 0.00118 seconds
Time Before: 0.00686 seconds
Time After: 0.00736 seconds
Time Before: 0.00759 seconds
Time After: 0.00770 seconds
Time Before: 0.00872 seconds
Time After: 0.01155 seconds
Time Taken: 0.00283 seconds
Time Before: 0.00775 seconds
Time After: 0.01504 seconds
Time Taken: 0.00728 seconds
Time Before: 0.01829 seconds
Time After: 0.01869 seconds
Time Before: 0.02190 seconds
Time After: 0.02667 seconds
Time Taken: 0.00477 seconds
Time Before: 0.01756 seconds
Time After: 0.02690 seconds
Time Taken: 0.00934 seconds
Time Before: 0.03920 seconds
Time After: 0.03933 seconds
Time Before: 0.05701 seconds
Time After: 0.05845 seconds
End call of global.php: 0.061009883880615
Time Before: 0.06295 seconds
Time After: 0.06310 seconds
Time Before: 0.06592 seconds
Time After: 0.06737 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=123662'
Time Before: 0.08128 seconds
Time After: 0.08153 seconds
Page generated in 0.080341815948486 seconds with 9 queries, spending 0.012054920196533 doing MySQL queries and 0.068286895751953 doing PHP things.
