Time Before: 0.00396 seconds
Time After: 0.00462 seconds
Time Taken: 0.00066 seconds
Time Before: 0.00475 seconds
Time After: 0.00519 seconds
Time Before: 0.00555 seconds
Time After: 0.00577 seconds
Time Before: 0.00702 seconds
Time After: 0.00982 seconds
Time Taken: 0.00281 seconds
Time Before: 0.00585 seconds
Time After: 0.01428 seconds
Time Taken: 0.00843 seconds
Time Before: 0.01701 seconds
Time After: 0.01745 seconds
Time Before: 0.02070 seconds
Time After: 0.02295 seconds
Time Taken: 0.00225 seconds
Memory Before: 2,148.938 KB
Memory After: 2,148.797 KB
Time Before: 0.01618 seconds
Time After: 0.02325 seconds
Time Taken: 0.00707 seconds
Memory After: 2,261.820 KB
Time Before: 0.03046 seconds
Time After: 0.03059 seconds
Memory Before: 2,815.367 KB
Memory After: 2,815.883 KB
Time Before: 0.03329 seconds
Time After: 0.03489 seconds
Time Taken: 0.00160 seconds
Memory Before: 2,903.563 KB
Memory After: 2,904.156 KB
End call of global.php: 0.037132978439331
Time Before: 0.03852 seconds
Time After: 0.03868 seconds
Memory Before: 3,540.328 KB
Memory After: 3,540.758 KB
Time Before: 0.04181 seconds
Time After: 0.04375 seconds
Time Taken: 0.00195 seconds
Memory Before: 3,821.859 KB
Memory After: 3,823.547 KB
SET lastactivity = 1788841713, location = '/forums/private.php?do=newpm&explain=1&u=123742', badlocation = 1
Time Before: 0.06195 seconds
Time After: 0.06231 seconds
Memory Before: 4,287.836 KB
Memory After: 4,288.047 KB
Page generated in 0.061012983322144 seconds with 9 queries, spending 0.010332584381104 doing MySQL queries and 0.05068039894104 doing PHP things.
