Time Before: 0.01147 seconds
Time After: 0.01882 seconds
Time Taken: 0.00734 seconds
Time Before: 0.01892 seconds
Time After: 0.01938 seconds
Time Before: 0.01960 seconds
Time After: 0.01972 seconds
Time Before: 0.02052 seconds
Time After: 0.02278 seconds
Time Taken: 0.00226 seconds
Time Before: 0.01979 seconds
Time After: 0.02712 seconds
Time Before: 0.03430 seconds
Time After: 0.03472 seconds
Time Before: 0.03795 seconds
Time After: 0.03940 seconds
Memory Before: 2,148.820 KB
Memory After: 2,148.680 KB
Time Before: 0.03356 seconds
Time After: 0.03964 seconds
Time Taken: 0.00607 seconds
Memory After: 2,261.703 KB
Time Before: 0.06631 seconds
Time After: 0.06650 seconds
Memory Before: 2,815.281 KB
Memory After: 2,815.797 KB
Time Before: 0.08378 seconds
Time After: 0.08504 seconds
Memory Before: 2,903.477 KB
Memory After: 2,904.070 KB
End call of global.php: 0.08714485168457
Time Before: 0.09318 seconds
Time After: 0.09332 seconds
Memory Before: 3,540.234 KB
Memory After: 3,540.664 KB
Time Before: 0.09577 seconds
Time After: 0.09725 seconds
Memory Before: 3,821.766 KB
Memory After: 3,823.453 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=123751'
Time Before: 0.11886 seconds
Time After: 0.11916 seconds
Memory Before: 4,287.188 KB
Memory After: 4,287.430 KB
Page generated in 0.11781287193298 seconds with 9 queries, spending 0.0080680847167969 doing MySQL queries and 0.10974478721619 doing PHP things.
