Time Before: 0.00141 seconds
Time After: 0.00190 seconds
Time Before: 0.00197 seconds
Time After: 0.00246 seconds
Time Before: 0.00267 seconds
Time After: 0.00284 seconds
Time Before: 0.00355 seconds
Time After: 0.00598 seconds
Time Taken: 0.00242 seconds
Time Before: 0.00288 seconds
Time After: 0.00941 seconds
Time Taken: 0.00652 seconds
Time Before: 0.01111 seconds
Time After: 0.01144 seconds
Time Before: 0.01389 seconds
Time After: 0.01505 seconds
Time Taken: 0.00115 seconds
Memory Before: 2,148.938 KB
Memory After: 2,148.797 KB
Time Before: 0.01053 seconds
Time After: 0.01522 seconds
Time Taken: 0.00469 seconds
Memory After: 2,261.820 KB
Time Before: 0.02030 seconds
Time After: 0.02049 seconds
Memory Before: 2,815.367 KB
Memory After: 2,815.883 KB
Time Before: 0.02289 seconds
Time After: 0.02416 seconds
Memory Before: 2,903.563 KB
Memory After: 2,904.156 KB
Time Before: 0.02696 seconds
Time After: 0.02708 seconds
Memory Before: 3,540.328 KB
Memory After: 3,540.758 KB
Time Before: 0.02912 seconds
Time After: 0.03063 seconds
Time Taken: 0.00151 seconds
Memory Before: 3,821.859 KB
Memory After: 3,823.547 KB
UPDATE session SET lastactivity = 1788990727, location = '/forums/private.php?do=newpm&explain=1&u=123764' WHERE sessionhash = '7fe2d67a1fab00498787d8dbbdf69797'
Time Before: 0.04347 seconds
Time After: 0.04376 seconds
Memory Before: 4,287.563 KB
Memory After: 4,287.781 KB
