Time Before: 0.00150 seconds
Time After: 0.00210 seconds
Time Taken: 0.00061 seconds
Time Before: 0.00218 seconds
Time After: 0.00260 seconds
Time Before: 0.00284 seconds
Time After: 0.00295 seconds
Time Before: 0.00385 seconds
Time After: 0.00659 seconds
Time Taken: 0.00274 seconds
Time Before: 0.00302 seconds
Time After: 0.01095 seconds
Time Taken: 0.00793 seconds
Time Before: 0.01288 seconds
Time After: 0.01329 seconds
Time Before: 0.01648 seconds
Time After: 0.01772 seconds
Time Before: 0.01216 seconds
Time After: 0.01799 seconds
Time Taken: 0.00583 seconds
Time Before: 0.02422 seconds
Time After: 0.02435 seconds
Time Before: 0.02629 seconds
Time After: 0.02752 seconds
Time Before: 0.03097 seconds
Time After: 0.03122 seconds
Time Before: 0.03426 seconds
Time After: 0.03573 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=123766', badlocation = 1 WHERE sessionhash = '5dcfbb55b5add1e7cfb509ae0e835a95'
Time Before: 0.05498 seconds
Time After: 0.05529 seconds
