Time Before: 0.01336 seconds
Time After: 0.01702 seconds
Time Taken: 0.00366 seconds
Time Before: 0.01713 seconds
Time After: 0.01762 seconds
Time Before: 0.01792 seconds
Time After: 0.01805 seconds
Time Before: 0.01884 seconds
Time After: 0.02091 seconds
Time Taken: 0.00206 seconds
Time Before: 0.01814 seconds
Time After: 0.02501 seconds
Time Taken: 0.00687 seconds
Time Before: 0.03058 seconds
Time After: 0.03083 seconds
Time Before: 0.03323 seconds
Time After: 0.03443 seconds
Time Before: 0.02991 seconds
Time After: 0.03462 seconds
Time Taken: 0.00471 seconds
Time Before: 0.05634 seconds
Time After: 0.05649 seconds
Time Before: 0.06586 seconds
Time After: 0.06715 seconds
End call of global.php: 0.069352865219116
Time Before: 0.07382 seconds
Time After: 0.07406 seconds
Time Before: 0.07681 seconds
Time After: 0.07827 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=123786', badlocation = 1
Time Before: 0.09723 seconds
Time After: 0.09753 seconds
Memory Before: 4,288.203 KB
Memory After: 4,288.430 KB
Page generated in 0.095914840698242 seconds with 9 queries, spending 0.0075838565826416 doing MySQL queries and 0.088330984115601 doing PHP things.
