Time Before: 0.00209 seconds
Time After: 0.00270 seconds
Time Taken: 0.00061 seconds
Time Before: 0.00280 seconds
Time After: 0.00322 seconds
Time Before: 0.00345 seconds
Time After: 0.00359 seconds
Time Before: 0.00446 seconds
Time After: 0.00716 seconds
Time Taken: 0.00270 seconds
Time Before: 0.00366 seconds
Time After: 0.01246 seconds
Time Taken: 0.00880 seconds
Time Before: 0.01521 seconds
Time After: 0.01561 seconds
Time Before: 0.01817 seconds
Time After: 0.01938 seconds
Time Before: 0.01442 seconds
Time After: 0.01965 seconds
Time Taken: 0.00523 seconds
Time Before: 0.02720 seconds
Time After: 0.02737 seconds
Time Before: 0.02973 seconds
Time After: 0.03095 seconds
End call of global.php: 0.032624006271362
Time Before: 0.03380 seconds
Time After: 0.03395 seconds
Time Before: 0.03591 seconds
Time After: 0.03731 seconds
Time Taken: 0.00140 seconds
SET lastactivity = 1780671444, location = '/forums/private.php?do=newpm&explain=1&u=123813'
Time Before: 0.04972 seconds
Time After: 0.05011 seconds
Page generated in 0.048841953277588 seconds with 9 queries, spending 0.0081901550292969 doing MySQL queries and 0.040651798248291 doing PHP things.
