Time Before: 0.02867 seconds
Time After: 0.04301 seconds
Time Taken: 0.01434 seconds
Time Before: 0.04312 seconds
Time After: 0.04356 seconds
Time Before: 0.04381 seconds
Time After: 0.04397 seconds
Time Before: 0.04500 seconds
Time After: 0.04842 seconds
Time Taken: 0.00342 seconds
Time Before: 0.04405 seconds
Time After: 0.05387 seconds
Time Taken: 0.00982 seconds
Time Before: 0.06812 seconds
Time After: 0.06856 seconds
Time Before: 0.07100 seconds
Time After: 0.07227 seconds
Time Before: 0.06746 seconds
Time After: 0.07247 seconds
Time Taken: 0.00501 seconds
Time Before: 0.11985 seconds
Time After: 0.12002 seconds
Time Before: 0.14786 seconds
Time After: 0.14914 seconds
Time Before: 0.16590 seconds
Time After: 0.16609 seconds
Time Before: 0.16890 seconds
Time After: 0.17040 seconds
Time Taken: 0.00150 seconds
UPDATE session SET lastactivity = 1776633797, location = '/forums/private.php?do=newpm&explain=1&u=123830' WHERE sessionhash = '0072f2714e5608fd7a8a8d7024a3e041'
Time Before: 0.18918 seconds
Time After: 0.18949 seconds
Memory Before: 4,288.266 KB
Memory After: 4,288.492 KB
